Original > Hot Tub Forum
Low Alkalinity High PH Problem
DJJ:
Thank you so much for the in depth post. I think that I have come to the conclusion that I will leave the Alkalinity at 30-40 if I can balance the PH. I just can’t seem to get both balanced at the same time. Also, I do have a Taylor Test Kit, so I know my readings are fairly accurate. Thanks again.
HotTubLife:
Yes. I have moved from the 'chlorinating granules' to ordinary household bleach. Seems to do the trick just fine, and I rarely need to add any. For my typical use, the salt cell alone is sufficient to keep the water crystal clear - especially in the winter. So far, no evidence that I should change my routine. Fingers crossed.
Navigation
[0] Message Index
[*] Previous page
Go to full version
