Original > Hot Tub Forum
Ozonators and Asthma
<< < (2/3) > >>
Tman122:
--- Quote from: CarsonCityNewbie on November 02, 2018, 11:00:17 am ---Getting an ozonator seems like a no brainer--less chemicals has to be  better, right? Then I found a few articles saying O3 could cause respiratory distress in asthmatics ... like me. Anyone heard about this or done any research?
--- End quote ---
If chlorine kills 100 bacteria ozone kills .0001
Jacuzzi Jim:
  In most cases as like mentioned the ozonator will only work with pump 1 in low speed.  But only during a preset filter cycle.  Turn pump to high it will shut off.
  Spa's with a circ pump the ozone will or should be on 24/7  but again once you hit that main pump btn the ozonator will shut off.   Least on Jacuzzi/Sundance brands same with Bullfrog. Because "they" don't want you using the spa with the ozone on.   With exception to D1 they were the only ones for quite awhile and maybe now a few others that have Ozone mixing chambers so no off gas.
hottubdan:
The reason it should be no issue for you is the ozone should be used up in the water.  There should be no off gassing.
wmccall:
--- Quote from: CarsonCityNewbie on November 02, 2018, 02:56:25 pm ---This is opposite of info one dealer told me. He said the ozone works with no circ pump because it immediately kills the bad stuff when you run the main pump and have it cycle through for about 30 min. That means no constant level of chlorine is circulating through your system. Why do you think ozone works better with 24 circ? ...Just trying to figure out if I need ozone feature.
--- End quote ---
On this subject, I claim no expertise, but I've purchased two tubs that had ozone, I kept one 9 years and the other 6 years so far.  Both had UV ozonators and the manufacturers said those bulbs would last about 2 years (from memory)  I assume they both failed at one point, I never noticed any difference.
The Wizard of Spas:
I'll also try an unpack some of this:
To dumb it down a bit, ozone lines tend to have bubble coming out of them.  Ozonators tend to have a life spa- 12-18 months for UV, 18-24 months for CD.  There are variations of these, and these variations can increase in the ability to sanitize the water, or increase the lifespan of the generator.  When the unit stops producing ozone, the only way to notice is to check the actual ozonator to see if the bulb is burnt out, or check the chip, etc.  In most cases, the bubbles will continue, regardless of whether the unit is working.
If you're really into ozone, you can notice the smell of the ozone when you open the cover.  That is always how I know whether or not it is working.
The quality of ozone has many layers:  How slow is the GPM of the ozone line tends to be the best indicator.  If the water is traveling too fast, ozone is not going to be effective.  Also- The length of plumbing will be an indicator of how well the ozone performs.  Also- The increased size of plumbing, or extras like mixing chambers, etc. can increase the effectiveness of the ozone.
Circulation pumps as a whole tend to be the better route, as others have explained.  It is a slower motor that runs 24/7.  But there are no ozonators that render your tub "Chemical-free," just as there is no way to treat a hot tub that is "Chemical-free."
Think of an ozonator just in the same fashion as your filtration system:  They can vary in quality, and can vary in their ability to help you keep your water clean, but they are only a small part of that, and in no way are a substitute for water chemistry, sanitation, etc.
I hope this helps.  Good luck moving forward.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
