Author Topic: Labor Day  (Read 5896 times)
Chris_H
Labor Day
« on: September 03, 2004, 04:22:35 pm »
All,
I just wanted to wish all of you a happy and safe Labor Day.
Also if anyone is interested helping on Monday, I will be at 12910 North Zuni Street in Westminster, Colorado helping Stuart finish dig his hole.
Chris H
Labor Day
Re: Labor Day
« Reply #1 on: September 03, 2004, 04:55:48 pm »
You're going to need a really high capacity scoop shovel if you're going there to dig around.
Re: Labor Day
« Reply #2 on: September 03, 2004, 06:45:26 pm »
Out labor day is without our hot tub  :( We are off to the National Buffalo Wing Festival!
stuart
Re: Labor Day
« Reply #3 on: September 03, 2004, 09:41:53 pm »
All,
Chris H
Are we digging a "bear trap" in JA's front yard?
stuart
Re: Labor Day
« Reply #4 on: September 03, 2004, 09:43:15 pm »
Honestly I think the only thing we will catch there is a weasel or a skunk!
keesterdog
Re: Labor Day
« Reply #5 on: September 04, 2004, 04:09:01 pm »
personally i would never dig in my friends hole.
butt that's just me. :o
Re: Labor Day
« Reply #6 on: September 04, 2004, 05:51:55 pm »
I just got called out to a delivery site where my guys needed help cutting up and lifting out an old in-ground shell. I tweaked my back.  :-[
Looks like I'll be spending the weekend laying on ice.
stuart
Re: Labor Day
« Reply #7 on: September 05, 2004, 11:48:51 am »
Learned a valuable lesson this year on that subject! First off only 10-15 minuets of ice at a time or you slow down blood flow then after 24 hours alternate 10 minuets of spa then finish with 10 mins on ice. Here’s the catch; the ice doesn’t do much good unless it's worked into the muscle so tie it in place and walk around a bit. This info came from a Doc for the Olympic Athletes!
Now’s a good time to get that book the E-myth I told you about, take a break and read!
« Last Edit: September 05, 2004, 11:49:44 am by stuart »
Re: Labor Day
« Reply #8 on: September 06, 2004, 12:16:25 am »
Ya know, I ordered that book - at least I got it into my 'shopping basket' at Amazon.com - but I got called away before completing the order.
I may go see about finishing that order now!
OnMedic
Re: Labor Day
« Reply #9 on: September 06, 2004, 08:20:03 am »
Ice = Decreased Blood Flow = Reduce Swelling (ie. Sprained ankle, fracture bone etc...)
Heat = Increased Blood Flow = Promote Healing
Either or, stuart is on the mark, 10-15 on and 10-15 off. I would never use ice on the back, you want heat to promote healing and keep the muscles around the damaged legiments loose. Most back injuries are Legiments that get streatched/strained.
« Last Edit: September 06, 2004, 08:21:27 am by OnMedic »
stuart
Re: Labor Day
« Reply #10 on: September 06, 2004, 11:57:30 am »
This is a good subject for the forum! The reason I talked to the Olympic doc that I know was because an MD recommended that one of my customers not use the spa because the heat caused swelling. After talking to several other medical pros I found most suggested not using the spa in the first 24 hours and then use it frequently but not longer than 10-15 minuets.  In all of my years of boxing we always used ice on joints and heat on muscle injuries. He told me to use the ice in conjunction with the heat and it would not only increase blood flow but it is now believed that it causes a chemical reaction that promotes natural healing to take place. I broke my sacrum bone in my back not long after and was amazed how well this combination worked for me!
OnMedic,
By your handle you must also be in the medical field so input on injuries and hot tubs are greatly appreciated!
Re: Labor Day
