Original > Hot Tub Forum
Hotspring Incentive Program / Free ACE System with Highlife series purchase
Aquatub88:
That’s concerning that you blew a cell. Isn’t the idea that this is supposed to be your sanitizer?
Is it really worth getting the salt generation ? Honest answers would be appreciated by users or past users of the system.
Tman122:
--- Quote from: Aquatub88 on May 03, 2018, 09:47:52 pm ---That’s concerning that you blew a cell. Isn’t the idea that this is supposed to be your sanitizer?
--- End quote ---
No, IMO any chlorine generation system is not worth it. Adding a small amount of chlorine after each use is so easy that if you want easier, your a dumb ass.
dishdude:
--- End quote ---
The warranty on the ACE system is only one year and the cell is $800. In my experience, using it as the sole source of sanitizer wasn't working but if I am out of town or not using it for a period of time it does a great job of keeping the water chlorinated. I have a small bottle with a tiny amount of Clorox (don't use the splash-less stuff!!!) I take in with me and set on the filter cover. As I'm about to get out, I pour it in and let it circulate before turning the pumps off. A tablespoon or two is all that is needed to bump the chlorine level up to 3 ppm and by the next day it'll drop down to about 1 ppm and with the ACE system set to a low level it'll keep it there without the need to remember to check in on it.
I suspect the ACE system also causes the PH to continually rise. I need to add PH reducer frequently to keep the PH 7.2-7.6.
You also need to take the cell out and soak it in muriatic acid once a month. Water the acid down, 2/3 water, 1/3 acid. Good time to rinse the filter off too.
dishdude:
--- Quote from: d00nut on May 03, 2018, 09:08:40 pm ---
--- Quote from: dishdude on May 03, 2018, 05:02:07 pm ---I doubt Costco would be charging me to fix something under warranty.
--- End quote ---
You doubt, which means you don't know. They would... FYI, a hot tub. Travel charges.
Also, most costco hot tub warranty's cover the parts for longer than the labor. So travel + labor. HSS gives the dealer the right to charge a trip charge, but no labor.
If your dealer wants to whine to you about the product they represent, I blame you for doing poor research on the dealer, and I look at the dealer as being someone who needs to get the heck out of the business.
I don't charge a cent for warranty work... FYI. I think it ruins the experience. I eat it, but I don't give my hot tubs away either, so I can do that.
--- End quote ---
You're right, I am to blame. I thought I was paying extra for a premium product that wouldn't need continual repair. Latest drama, both pumps are leaking. I was told the Chinese "guangdong" pumps that came from the factory aren't the greatest. Luckily they're being replaced with an Aquaflo that is supposed to be higher quality.
castletonia:
--- Quote from: dishdude on May 03, 2018, 11:20:08 pm ---
--- End quote ---
--- End quote ---
Everyone's mileage will vary. I only have about a year in with ACE, but I don't have any customer's who continually need to add chlorine to supplement ACE. I'm guessing you are trying to run ACE with too low of an output setting?
ACE does not cause pH to rise. If anything, its the opposite. Aeration from the jets naturally causes pH to rise. When you add MPS, stain & scale products, even dichlor, those are all acidic or slightly acid and over time cause pH to drop. If you are using bleach to supplement ACE, that is why you pH rises. Bleach has a pH of 13.0
Again, sounds like your dealer did not properly educate you on ACE maintenance. If they did, you would have known from the getgo that the cell needs cleaning every 90 days. It's no different than a salt cell in a swimming pool, it needs regular cleaning.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
