Original > Hot Tub Forum
Upgrading Hottub
Jacuzzi Jim:
Yes there is, either a o-ring or a flat ring with raised o-ring molded into the flat part.
It might be there, but just old and not sealing right.
Tman122:
--- Quote from: Jacuzzi Jim on April 02, 2018, 03:51:16 pm --- Yes there is, either a o-ring or a flat ring with raised o-ring molded into the flat part.
--- End quote ---
And use a good gasket lube while your at it. Majilube.
Matt132:
Thanks guys!
The rubber ring is there and is till in good condition. I think it wasn't sitting flush when i lined the pipe up with the pump so ive had to put a packer under the pump. Will try it tomorrow as the weather was horendous for working outside today!
Matt132:
Update*
I ordered a new Lx Flow type Heater and a new circ pump.
There is pressure switch lead that comes from the heater. Does anyone know where to wire the 2 cables into? Is it just a positive and negative and i can link it in to the main powere feed cables?
<a href="https://ibb.co/gxSFZ7"><img src="https://preview.ibb.co/mMXhE7/20180417_200806.jpg" alt="20180417_200806" border="0"></a>
<a href="https://ibb.co/gAZJnS"><img src="https://preview.ibb.co/buDpu7/20180417_165504.jpg" alt="20180417_165504" border="0"></a>
Matt132:
Navigation
[0] Message Index
[*] Previous page
Go to full version
