Author Topic: Marquis pump question  (Read 6069 times)
Chief Kyle
« on: December 10, 2015, 03:01:00 am »
So, I just noticed...well not quite true it just never really concerned me...so here's the question:  When I turn on the #2 jets (Marquis Epic) the #1 jets come on, every time, is this what is to suppose to happen?
MarKee
Re: Marquis pump question
« Reply #1 on: December 10, 2015, 01:43:39 pm »
Hey Chief, it's probably kicking on pump #1 because it assumes the spa is losing temperature and it needs to run pump #1 to heat.  I think you can bypass this by hitting your "Quiet Soak" button, which will then allow you to just run pump #2.
Chief Kyle
« Reply #2 on: December 10, 2015, 06:42:59 pm »
The quiet soak option worked...thanks
