Author Topic: How do you use your Hot Tub?  (Read 10454 times)
ZzTop
  • Beachcomber 550x owner
« on: July 01, 2004, 06:22:33 pm »
Are you a Jet addict or a Soaker?
How long do you stay in?
Do you like a foot reflex massage?
Do you run your pumps on high speed most of the time or on low?
Which seat do you like most?
Do you like deep seats or high?
Do you finish up in your lounger?
What time of the day do you use your Spa?
How often per week do you use your hot Tub?
What temperature do you run your spa at?
How long have you owned your hot tub?
What make and model of Spa do you own?
« Last Edit: July 06, 2004, 03:20:49 pm by ZzTop »
Re: How do you use your Hot Tub?
« Reply #1 on: July 01, 2004, 06:31:39 pm »
I'm a soaker all the way. I'll have the jets on a few minutes but 80% of the time I'm simply lying back and relaxing as if I'm a single guy without a care in the world. Then reality hits and the kids get in and invariably look at me and say "Can I turn the jets on" to which I give them 10 minutes or simply give up control of the spa altogether and go back to my life of servitude.
Roborph
« Reply #2 on: July 01, 2004, 11:43:32 pm »
 I like them on high, the more bubbles the better!
 When my kids get in, they want the jets off- who in the heck raised them?
« Reply #3 on: July 02, 2004, 06:03:57 am »
We just have wild sex partys in ours. Spillin stuff, splashing water out hollorin.
« Reply #4 on: July 02, 2004, 08:03:53 am »
  Soaker
  usually between 60 and 90 minutes.
  Not sure what that is.  I like the foot jets.
 High
The "Throne".  (Main therapy seat)
 Yes
 No
Usually between 10 pm and midnight
No less than once, usually 2 or 3.
 usually around 100.
 about 1 year
« Reply #5 on: July 02, 2004, 08:08:05 am »
Yes.
How long do you stay in?  For therapy 20 minutes at high  temps - relaxation or socially 30-60 minutes at reduced temp.
Do you like a foot reflex massage? -yes
Do you run your pumps on high speed most of the time or on low?  50/50
Which seat do you like most? -depends on the ache and pain of the day.
Do you like deep seats or high?  seats
Do you finish up in your lounger? frequently, but its my daughter's favorite.
What time of the day do you use your Spa? usually 90 minutes before bed, but very early weekend mornings are a favorite too.
How often per week do you use your hot Tub? 5-8 times
What temperature do you run your spa at? 101-104, sometimes 99 socially.
 18 months
« Last Edit: July 02, 2004, 08:08:36 am by wmccall »
Bill_Stevenson
  • Hot Spring Envoy
« Reply #6 on: July 02, 2004, 10:13:10 am »
Jet addict
Only about 20 minutes, but that will increase when my personal spa comes and the temp can be lowered.  For now the spa I use is a community item.
Yes very much
High
Current spa has bench seats.  I like the lounger on the new spa followed by the chair
Yes.
No
Always late in the evening just before bed
4 or 5 times
Currently set at 102, I would prefer 99 or 100
4 years for current community spa, new spa on order for new house still under construction
« Reply #7 on: July 02, 2004, 11:31:37 am »
Soaker...will put jets on for 10-15 minutes and spend the rest of the time on low speed with just the whirlpool jets moving the water.
Usually 30 - 40 minutes
The therapy seat (it is the deepest)
I like the deep seats
Don't have a lounger
I use the spa just about every day early in the AM with coffee.  About 2-3 time per week I use it at night between 10-12.
102 in winter, spring and fall...100 in summer
2 years.
« Last Edit: July 02, 2004, 11:32:54 am by tony »
usuallytrue
  • Sundance owner
« Reply #8 on: July 02, 2004, 11:36:11 am »
Jet addict and I love the air bubbles
20 -30 min
yes
Do you run your pumps on high speed most of the time or on low?   50/50 - I'm still trying things out
Lounger believe it or not
both
No, I like to start there - I positioned my tub so the lounger would have the best view...
anytime after work or later on the weekends...
so far at least 5
101 right now - probably will go warmer in winter
Just over a month - can't believe I waited so long to get one...
doodoo
« Reply #9 on: July 02, 2004, 02:47:49 pm »
I'm both. I usually start off with just soaking and the after 20-30 minutes turn on the jets low. a little while later I turn on some jest on high for about 10 min.
Depends. Are the kids awake? or asleep?
That is the very best for me. I always finish off my soak with the feet. OOOOOHHHHYAAA BABY!
On low usually.
All of them for varying reasons.
I prefer the deep ones. But if I'm enjoying a fine cigar with a peatty scotch next to my sex goddess (Wife) then I prefer the higher seats so that I can keep my hands dry.
Do you finish up in your lounger? We don't have a lounger proper but two of our seats are configured so that you can lounge out comfortably and no I do not finish up there.
Morning sometimes and night always.
6-7
101 for now. I may increase the temp as winter approaches.
3 months.
t6texan
  • Tiger River Begal
« Reply #10 on: July 03, 2004, 06:42:36 pm »
Are you a Jet addict or a Soaker? jets!
How long do you stay in? 40-50 minutes
Do you like a foot reflex massage? yes
Do you run your pumps on high speed most of the time or on low? high
Which seat do you like most?  upright seat across from foot jets
Do you like deep seats or high? yes
Do you finish up in your lounger? no its best for soaking
What time of the day do you use your Spa? nite after 9:00
How often per week do you use your hot Tub? 5- 6 times
How long have you owned your hot tub? 3months
T6texan
jdmanteca
« Reply #11 on: July 05, 2004, 08:44:15 am »
I tend to start with jets on high and then finish with on low - more of a soak
1/2 hour and higher temp (102) and longer at lower temp(99-98) when just soaking socially.
I think.  I like my foot jets.
Do you run your pumps on high speed most of the time or on low? high at first and then low
I give most of them equal time but prefer my lounger and therapy seat.
Do you like deep seats or high? I like to start in the deep seats (lounger/therapy seats) and then finish out of the water somewhat to cool down.
Nope - see above
Usually in the evening when air temp cools down (it's hot right now in Texas)
Mine is fairly new, so just about daily
See - above
about 6 weeks
Lori
« Reply #12 on: July 05, 2004, 01:28:08 pm »
Are you a Jet addict or a Soaker?  Jet Addict
How long do you stay in?  30 minutes or so
Do you like a foot reflex massage?  Yes
Do you run your pumps on high speed most of the time or on low?  Only one speed!
Which seat do you like most? My moto-massage seat with the Hydro-pulse plate
Do you like deep seats or high?  Both, depending
Do you finish up in your lounger?  Don't have a lounger
What time of the day do you use your Spa?  Usually evening, but early morning is good, too.
How often per week do you use your hot Tub? 4-5
What temperature do you run your spa at?  Usually about 100 in winter, 97-96 in summer.
How long have you owned your hot tub?  10-11 months
SpaAngel
« Reply #13 on: July 05, 2004, 11:00:41 pm »
Jet addict for sure!!!
20-30 mins.
Who doesn't???
Initially, high, then down to low.
I love them all (even the deep ones).
Both.
Never.
Evening hours, usually 9:00 p.m.
About 5 times a week.
101
Almost a full month now, and lovin' every minute of it!!!
beachman
« Reply #14 on: July 06, 2004, 12:15:24 am »
Are you a Jet addict or a Soaker? love the jet power!
How long do you stay in? 1/2 to an hour or longer
Do you like a foot reflex massage? yep
Do you run your pumps on high speed most of the time or on low? high most of the time
Which seat do you like most?  most jets and the deepest
Do you like deep seats or high? deep
What time of the day do you use your Spa? all hours
How often per week do you use your hot Tub? 3-5 times
What temperature do you run your spa at? 104 I acually got it up to 106 today! new record (love the heat)
How long have you owned your hot tub? 1 1/2 years
