Author Topic: Hello Everyone! I'm in the market for a Hot Tub!!!  (Read 4788 times)
bareyb
« on: June 22, 2004, 03:51:42 pm »
I'm ready to take the proverbial "plunge" and start Wet Testing some Spas. Our old Wildwater has finally died and it's time to upgrade. I'm considering Sundance (first choice, mainly due to the opinions on this site), Hot Springs, and Jacuzzi Premium. I have visually inspected all the brands above and think they all look pretty good. I guess the Wet Test is the biggie eh? We are loading up the car and getting ready to go do the deal.
Mainly just wanted to thank everyone here for all the good advice and your experiences. I have two Kids and they both love to "Tub". I also have an old back injury that gives me grief from time to time so a good "therapeutic spa" is really just what the Dr. ordered.
Questions:
1. What do you guys consider the BEST Spa in terms of overall quality and design?
2. Which Spa do you consider to be the BEST OVERALL VALUE?
3. Which Spa do you feel has the most Therapuetic Jets? Volume vs. Pressure etc.
« Last Edit: June 22, 2004, 03:53:14 pm by bareyb »
empolgation
  • you pay what you get it for
Re: Hello Everyone! I'm in the market for a Hot Tu
« Reply #1 on: June 22, 2004, 04:18:43 pm »
That's easy... the tub i buy (or sell)  ;D
bareyb, there is no one correct answer to your questions - it's all way too subjective.
1. It looks like you've already done your homework and have choosen 3 brands that could easily be the correct answer for you.
2. Again, it's in the homework, there is a lot of great info in this forum and others to help you get a grip on the advantages of features and fair price for particular tubs, armed with that you can correctly answer which one is best for you.
3. Your wet test will give you the correct answer for you.
You appear to be going about it the right way...
- do your homework and wet test and you will find the correct answer to your questions for you.
« Last Edit: June 22, 2004, 04:19:11 pm by empolgation »
e
saz
« Reply #2 on: June 22, 2004, 04:40:58 pm »
I agree with empolgation.....we made FAR too many decisions based on what we thought we wanted, and what we didn't before wet testing........all I can say is WET TEST, WET TEST, WET TEST...and then when you've done that, WET TEST some more!! You'll know when you find the hot tub that is right for you.
saz
« Last Edit: June 22, 2004, 04:41:33 pm by saz »
ndabunka
« Reply #3 on: June 22, 2004, 06:06:48 pm »
I own a Jacuzzi J370 and believe that it is a good value for the price. Great looks, name brand recognition, solid local support, agressive pricing (for features), nice features (Stereo, Ozone, good insulation, low running costs, decent jet pressure, etc). Having said all that I would still encorage you to try out the other major brands like Hot Springs, Caldera, Master, Marquis, Dimension One, Beachcomber, Bullfrog, Coleman as all these vendors have good products at competitive prices. Stay away from the "mom & pop Built here" kind of shops unless your budget is below $5K as the major brands offer good products above the $5K level. My best recommendation to you is to pick a price point. See what's out there at that price point. Determine if any of those products fit your needs and be prepared to raise the price point. You should be able to buy A TOP OF THE LINE hot tub from a MAJOR mfg for under $8,000 with most bells and whistles (TV's may be more $'s).
« Reply #4 on: June 22, 2004, 07:21:17 pm »
I very much agree with Bunka's advice except the stereo part. They are costly if you compare them to the same spa without the stereo and not very reliable regardless of the fact they're "marine grade".  I'm certainly not a fan of spas with TVs in them either and not because you're supposed to be escaping TV while in a spa but again, they are too costly and too unreliable.
Now if you can get one with a microwave! ::)
chaz
« Reply #5 on: June 22, 2004, 08:11:58 pm »
Hi Bareyb,
I usually do not get to involved in these discussions because I am on the west coast and it seems most are from the East or Midwest.  I am extremely happy with my LA SPA Heet.  Even though you don't find it mentioned here often we have found it to be a good value well designed tub with many useful options.  Since you are in Cali I thought you might want to add it to your list.
Chaz
