Author Topic: naked lady --ice cold Bengal hot tub  (Read 7290 times)
drzonker
« on: June 20, 2004, 12:49:53 pm »
Hi
I have been enjoying my new 2004 bengal hot tub since hook-up and iinstallation Friday afternoon.  It has worked perfectly heat, jets ect since hook up.
Not to be graphic, but this morning I jumped out of bed, tore off my nightgown, went out the back door (with just a towel) and stepped into a cold hot tub.
The control panel said power and nothing was working.  So I went to the emergency switch (b/c it is on a 220 line) and flicked it.  Immediatley the jets worked but it seems that the heater will turn on, trip the circuit and then I have to open the panel and flick the heat switch inside tpo have it happen again.
I called my dealer and they have to call me back on Monday when there is a service tech.
The dealer says he has never heard of this occuring in brand new models.
Anyone have any clue?
lisa
Mendocino101
Re: naked lady --ice cold Bengal hot tub
« Reply #1 on: June 20, 2004, 01:33:04 pm »
...Hi Lisa....I think I can help but I will need to see a picture of you steping into the tub after losing the towel... ::)..uhhhh.....I..I...I...I......I think there is a connection somewhere....post the pictrue so we all can help..... ;)
drzonker
« Reply #2 on: June 20, 2004, 01:53:57 pm »
I weigh 320 pounds and I have skin problems --sorry to crash any sexual illusions you might have had.
Any watkins dealers with any clue out there?
« Reply #3 on: June 20, 2004, 02:04:07 pm »
 :o How ya feeling now Mendocino? :D LOL
Sounds like it could be a faulty heater element.
drzonker
« Reply #4 on: June 20, 2004, 02:11:07 pm »
Steve,
Is that easily fixed by the dealer?  Do they just put another one in?
Thanks for your input.
lisa
Mendocino101
« Reply #5 on: June 20, 2004, 02:37:52 pm »
hummmmmm.......how bad is the rash...(skin condition).. ;D...lol...sorry.....just teasing...hope you get your dealer out there....I am sure it is an easy fix....
« Reply #6 on: June 20, 2004, 02:59:59 pm »
It should be a straight forward fix.
« Reply #7 on: June 20, 2004, 03:53:12 pm »
Lisa,
Put on some clothes, and try this:
Turn off both breakers.
Pull out your filter and give it a good rinse with the garden hose. Use your neighbor's, they have better water pressure, and they're not home anyway  ;)
Put the filter back in, and turn on only the 20 amp breaker.
Run the jets for about ten minutes.
Turn on the 30 amp breaker.
Check the temp in about an hour, and let us know how it is.
« Reply #8 on: June 20, 2004, 10:01:22 pm »
Hey Lisa!
It's been over an hour.......  ;)
