Author Topic: newbie looking at a new hot tub.caldera or maax.  (Read 3823 times)
793bob
« on: September 08, 2013, 10:21:05 pm »
looking at buying our first hot tub and have looked at the caldera geneva and a maax 471.our local dealer sells the maax and the caldera dealer is an hour away but read the caldera is far better.are the pumps on the geneva 56 frame rate and is having the circulating pump better.any info on the caldera  would be a great help.thanks.
Re: newbie looking at a new hot tub.caldera or maax.
« Reply #1 on: September 09, 2013, 01:46:58 pm »
Circ pumps that take care of the filtering have the advantage of lower energy usage and noise reduction as opposed to having the main pump coming on 6 hours per day to filter plus if the spa has ozone it will run 24/7 on a circ pump. Having said that, you don't buy a spa based on whether or not it has a circ pump so what you should do is schedule a wet test for both spas and see how each fits/feels.
« Last Edit: September 09, 2013, 01:52:15 pm by Spatech_tuo »
« Reply #2 on: September 09, 2013, 06:15:08 pm »
And look under the hood to see how they are built.
