Author Topic: 2003 vs 2004 jacuzzis  (Read 6688 times)
dazedandconfused
  • Still Negotiating ....
« on: June 06, 2004, 07:33:09 am »
I have a 2003 Jacuzzi brochure.  Did the the 380 become the 385, 370 to 375, 360 to 365 etc etc?
Looks like the 375 is the SD cameo and the 355 is a slightly smaller optima by 7 inches in each dimension.
Am I correct?  Any diff's between 2003 and 2004?
dazedandconfused
Re: 2003 vs 2004 jacuzzis
« Reply #1 on: June 06, 2004, 07:48:57 pm »
Can anyone help me?
Jay_Suede
« Reply #2 on: June 06, 2004, 08:37:18 pm »
The 2003 J-340 turned into the 2004 J-365.  The 2003 J-360 became the J-365.  I heard the 2003's did not have fiber optic lighting under the waterfall, and a different control panel.
superted
« Reply #3 on: June 11, 2004, 05:59:43 pm »
2003 j-360 became 355 and 350 became 345. Less jets in the 355 than 360, and no led lights in 345 otherwise same tubs.
johnnythunders
  • Jacuzzi J-355
« Reply #4 on: June 11, 2004, 09:50:27 pm »
So you a`re saying i got robbed with my J-355,,,,Dammmmm i got screwed :-*Johnny Thunders
dpgtech
  • Jacuzzi Premium/Coleman / tech&deliverysp ecialist
« Reply #5 on: June 13, 2004, 05:43:22 pm »
The only difference between the 2003 J-360 and the 2004 J-355 is 5 less jets.  everthing else is the same.  they did not change the control panel and that model always had fiber optic waterfall lights.  yes they changed the model numbers by adding a 5 to the end
2003: 310,320,330,340,350-380, 2004 315,325,335, 345( which was the 350) 355, (which was the 360), 365( which was the 340) 375,385.
