Author Topic: Viking II Spa Quits Running Then Starts Again  (Read 5074 times)
xring600
« on: April 15, 2013, 06:46:40 am »
 I have a Viking II spa that shuts off and displays the error 6y of dy on the control panel. I hit the jet button and it will almost always start running again and heat back to 102. Any ideas? Thanks.
bimmerdog
Re: Viking II Spa Quits Running Then Starts Again
« Reply #1 on: April 15, 2013, 11:14:44 am »
 click  and scroll down to page 12 it has your answer      http://vikingspas.com/2012englishownersfinal.pdf
xring600
« Reply #2 on: April 15, 2013, 05:03:53 pm »
Thank you! Cant figure this one out as my water level is good. Time to investigate further.
Hottubguy
« Reply #3 on: April 15, 2013, 07:44:27 pm »
That code usually means not enough flow through heater. Pull the filter out and see if the problem persists
« Reply #4 on: April 16, 2013, 02:11:45 pm »
Hopefully just an old filter.
xring600
« Reply #5 on: April 19, 2013, 06:50:34 am »
Took filters out and am still having the same problem. Except now the pump will not start at all........only get a humming noise when I press the jet button on my overhead control.
