Original > Hot Tub Forum
Spa Shell Color
Brewman:
Our spa (Different Brand) has the sandy beige color, and the lighting is nice. We have a led light that constantly changes color.
ZzTop:
Color of the Tub. Â The white colors reflect the light at night best however shows the most dirt, Â A Tub with a rough textured surface does not show scratches, smooth surfaces will show scratches, Â the darker colors wear well, your choice. Â
You might consider the new LED lighting which is very energy efficient. Â You can get a light show of changing colors which is very impressive at night. Â Lighter tub colors can use fewer bulbs than dark. Â That is 7 for light colors and 22-24 for dark tubs.
You can install this type of lighting yourself and you will find it is much cheaper than what most hot tub dealers are asking for it factory installed.
Here are some links regarding LED lighting option.
http://www.spapartsdepot.com/cgi-bin/cshop/spaparts/color-glo.tam
http://www.hottubessentials.ca/mood_light_LED.asp
You must have a light switch on your tub that does not have a dimmer, just on and off.
Email an enquiry to the seller with the make, model and year of your Hot tub to make sure it is compatible before ordering.
Happy Tubbing,
Regards, Zz
Brewman:
I've been told that the platinum finishes are particularly striking with the LED lights.
Wisoki:
Buy what ever the dealer has in stock and ask for a discount for selecting from inventory. Color should have no bearing on your spa buying decision. Since the cover is on 95% of the time, what you see is going to be the cover and cabinet. If earth tones match your house, get the brownish redwood look. If gray is more fitting, get the gray cabinet and cover. It realy doesnt matter what color the spa is. Most users are in the spa in the evening hours any how. Even if you have a platinum shell you aren't going to sit in your hot tub thinking to yourself: "I sure am glad we got this color tub, look how pretty the lights are!" More likely it'll be: "Ahhh, honey turn those dang lights off so I can see the prettiest lights of all, the ones God created, the stars."
wmccall:
--- Quote ---Â A Tub with a rough textured surface does not show scratches, smooth surfaces will show scratches, Â the darker colors wear well, your choice. Â
--- End quote ---
This was our logic in choosing the "moonscape" textured surface.
Though, I sure liked the look of other smooth surface tubs I have seen in the showrooms. For those of you who have had smooth surfaces for a few years, do you have scratches? Where do they come from? People's jewerly or maybe from hoses? Just wondering...
Navigation
[0] Message Index
[*] Previous page
Go to full version
