Author Topic: Help with water treatment.  (Read 6912 times)
tinybubbles
« on: October 15, 2007, 10:03:14 am »
Hi, I'm a new spa owner and loving it.  So far, taking care of the water has been a breeze.  I'm using chlorine and I just throw in 2 capfuls after soaking.  My question is:  What do you do when you are going to be away for several days?  It's not unusual for us to take 5-7 day vacations.  Should I add extra chlorine before I leave?
Re: Help with water treatment.
« Reply #1 on: October 15, 2007, 10:09:00 am »
You could do that, it's probalby okay for short periods of non use.
Then zap it again when you get back.
jfish63
  • 2002 HS Grandeee
« Reply #2 on: October 15, 2007, 01:04:02 pm »
Also turn the heat down. Higher temps burn up the chlorine
tinybubbles
« Reply #3 on: October 15, 2007, 02:06:08 pm »
Thanks for the help.  I hadn't thought about turning down the temp, good suggestion.
« Reply #4 on: October 15, 2007, 06:13:45 pm »
Here's what I do that seems to work.
Hit it with a shock level of dichlor (10-12 PPM), turn down the heat as suggested, make sure the ozonator is running 24/7 (You have an Artesian I believe - you can change that timing), close and lock the cover (peace of mind only) and open up when I get home and hit it again with about 6 PPM and see how it is 20 minutes later.
My water typically stays clear under normal usage for 2 days but for some reason by doing the above I can get a week, I haven't gone longer - it may stay but may not.
ssbraun
  • '05 Maxxus
« Reply #5 on: October 15, 2007, 07:22:32 pm »
If I'm going for 2-3 days, I'll hit it hard with dichlor just before I leave...more than that and I ask a trusted friend to add dichlor every 3 days (about 2 tbsp.).  Some insurance companies require that your house be checked every 24-48 hours if you are gone more than 2 days anyway, so I just explain the pump operation to whoever is checking the house, and then I don't have to worry about it  :)
tinybubbles
« Reply #6 on: October 16, 2007, 10:04:44 am »
I figured that I would need to call on a neighbor for help during extended trips.  I just hate to be a burden.  Vinny, I already have my circ. pump running 24 hours, do you do this?
kimdupuie
« Reply #7 on: October 16, 2007, 10:26:50 am »
If you have the 24 hour circulation pump, does that automatically mean you have the ozonator?  Or is that totally different and you can have one but not the other?
tinybubbles
« Reply #8 on: October 16, 2007, 11:18:58 am »
You could have one without the other. :)
« Reply #9 on: October 16, 2007, 12:54:50 pm »
Artesian's have the unique ability (?) to control the amount of time the ozonator runs. The circ pump will run for 24 hours a day but the ozonator may only run for 2 or not be running at all. It depends on your "filtering time".
« Reply #10 on: October 16, 2007, 01:01:18 pm »
Ozonators are plumbed into the filtering line, whether you use a 24/7 circ pump or a two speed pump for filtering. Having a circ pump gives you the advantage of running ozone 24/7 but ozonators are typcially an option to add (some manufacturers make them standard on their upper models) and I personally would not go without one.
tinybubbles
« Reply #11 on: October 17, 2007, 10:48:14 am »
Holy Smokes.  Now I am confused!  I haven't had my orientation yet.  I just can't spare the time at work.  I assumed that the ozonator needed to run 24 hours a day, just like the circulation pump.  I thought (or think) that my circ. pump only runs during my filter cycle, which I have set for 24 hours.  The whole time that my circ is running, my ozonator is running.  Is this right?
WooWho
« Reply #12 on: October 17, 2007, 11:57:00 am »
TinyBubbles - we just went away for a week (first time we left since we've had our tub) and I was on the fence as to how to handle....
After soaking I usually add 1Tbs dichlor to our tub which is just under 500 gal.  We can go 2-3 days w/out chlorine if we don't soak.   I was going to ask my dad come mid week and add a couple Tbs but decided instead to super chlorinate.  Just before leaving I added 4 Tbs of Dichlor and let the pumps run for 45 mins w/ cover open to off-gas.  Then locked 'er up and prayed. :)
Came home expecting to find cloudy water but it looked sparkling clear, not a hint of cloudiness.  We only had one test strip left so I assumed there was no chlorine left and added the normal 1Tbs.  Tested water 20 mins later and it was perfect!  We have a mineral cartridge, but no ozone.
Didn't think to turn down heat signficantly (to minimze burning up the chlorine) but I did reduce to 98 or so to save energy.  Next time I'll probably reduce a lot more.  Good luck.
« Reply #13 on: October 17, 2007, 12:12:56 pm »
And nasty things grow faster in unattended hot water.
tinybubbles
« Reply #14 on: October 17, 2007, 12:56:45 pm »
Thanks woowho.  So WM, what temp would you recommend turning it down to?
