Original => Hot Tub Forum => Topic started by: keithtc on November 10, 2005, 12:38:38 am
Title: clear choice all natural "no brom or chlor"
Post by: keithtc on November 10, 2005, 12:38:38 am
in the procees of buying hot tub.
JACCUZI DEALER TOLD ME ABOUT "CLEAR CHOICE" ADVISED IT WAS ALL NATURAL AND YOU DID NOT NEED CHLORINE OR BROMIDE
ALSO NO NEED TO CHCK PH LEVELS DOES ANYONE KNOW ANYTHING ABOUT THIS
HOT SPRINGS AND JACCUZI DEALERS BOTH RECOMMENDED AGAINST BUYING OZONATER NEED ADVICE ON THIS
Title: Re: clear choice all natural "no brom or chlor"
Post by: Spatech_tuo on November 10, 2005, 12:53:51 am
I don't know what Clear Choice is. My experience is anything that promises you can avoid using a standard sanitizer is based on telling you what you want to hear to amek the sale but in the end when your water looks like soup you'll be buying some chlorine or switch to bromine. Either way, you can use any water treatment system on any spa so don't let that be a selling feature either way.
As far as ozone goes, I am a fan of them (the CD type specifically) as I know they HELP you maintain the water but it does not totally relieve you of your water care responsibility and you don't HAVE to have it. Again, all spas have them so this shouldn't really affect which spa you buy either.
Post by: Tman122 on November 10, 2005, 05:00:13 am
Theres alot of products out there that claim this but from what I have tryed and what I have read a claim is all that it is. After a while you end up adding chlorine to get what you think is clean water.
There are numerous PH lock products on the market.
An ozonator can help to reduce slightly the amount of sanitizer required between soaks.
Post by: AZJohn15 on November 10, 2005, 08:42:15 am
I started out with Clear Choice in my last spa.  It's an enzyme based sanitizer.  I didn't like it at all.   Left the spa feeling slimey all the time.  Switched over to Natures 2 liked that much better.
Post by: bulmer4nc on November 10, 2005, 02:34:41 pm
I'm hoping you switched to something else in addition to Nature 2...  N2 alone is not enough to sanitize your spa.  It can greatly reduce the amount of sanitizer you need but you still need something dichlor to go along with it.
Post by: drewstar on November 10, 2005, 02:48:05 pm
Okay, I'm getting confused. And it's not the first time :)  I'm hoping someone can clear this up in simple straigh forward terms using small words.
Natures 2 is  the Ozinator from HS, right?
There are, for the most part 3 major Chem routines.
1) Dichlor + Shock
2) Bromine + Shock
3)The Buaqua  crowd (enzimes).
You can use  an Ozinator with any of these, or none at all.
IS that right? When we talk chems, 99% of the time  the poster should fall into one of the above.
So when someone says "nature 2" they are talking about Hotsprings Dichlor and Ozinator routine.
Right? Or am I full of it?
Post by: orlandoguy on November 10, 2005, 02:49:12 pm
Why did the Jacuzzi and HS dealers advise against ozonators?  Mine highly recommended it and I am glad he did.
Post by: East_TX_Spa on November 10, 2005, 02:49:56 pm
Freshwater III is the HotSpring ozonator's official title.
Nature 2 is some brand name silver ion cartridge, I believe.
Terminator
Post by: East_TX_Spa on November 10, 2005, 02:51:09 pm
Of course he did, you put an extra $200 in his pocket more than likely.  Not all dealers are out to save you money. :)
Terminator
Post by: orlandoguy on November 10, 2005, 02:59:22 pm
Can you elaborate?  The model I chose had the ozonator, I wanted the ozonator, and got the ozonator.  Are you saying it's a waste, or he overcharged me?
Are there ANY dealers who look to save their customers money?  I realize many here are looking to make friends over money, but my impression of the industry is that the dealers generally rank slightly below used car salesmen on the food chain and ooze slightly more sleaze.
Post by: drewstar on November 10, 2005, 02:59:36 pm
Terminator
Ahhh. Now it makes a bit more sense. The HS dealer slapped one of these into my tub and I was wondering why that name was floating around my noggin.
It's actually time for me to get a new SIlver ion pack. I am debating if  I should or not.   Suggestions?
Post by: East_TX_Spa on November 10, 2005, 03:06:38 pm
Please don't misunderstand me.  My only comment was directed at your dealer highly recommending it.  If that's what you wanted and you're happy with it, good.
Is it a necessity?  If they were guaranteed to last for 10 years, yes, everyone should get one.  Do they sometimes quit working after a year or two?  Sometimes, and it is an expense to repair or replace.
If someone comes to my store and asks about the ozonator, this is exactly what I tell them.  I do not try to convince them that it will make their spa chemical-free or will save them money.  It will supplement their water care program, that's it.  Some people feel like it's worth it.
I really do try to make sure the customers know exactly what they're getting.  I'm going to be here for a long time and I don't want someone coming in ticked off at me because I sold them something they didn't need, that's all. :)
Terminator
Post by: hymbaw on November 10, 2005, 03:10:23 pm
Nature2 is indeed silver ions.
Ozone can be used with bromine, chlorine, and Nature2.
Ozone is not recommended with Baqua, which is not enzymes. It's biguinide, which is a synthetic polymer compound.
Post by: drewstar on November 10, 2005, 03:15:21 pm
Thanks for helping to clear it up.
I get the impression that you classify Nature 2 on the same level as Bromine and Dichlor, in that it's a principel sanitizing method to be used.  Is that correct?
I was under the impression that products like Nature 2 can assist in keeping water clean (many public pools used an ion system), but this was in addition to not instead of, Bromine or chlorine. Much like ozone (it helps,  but on it's own has not been proven to be a vaiable complete method).
Real people are claiming success with just an ion pack?
My tub has an ozinator, a Nature 2 ion cartridge, I use dichlor after each soak, and shock every week.
Am I over doing it?
Post by: Guzz on November 10, 2005, 03:18:04 pm
I'm with you on this Term, Ozone does help but it's not the god send every one makes it out to be, you still have to sanitize the spa. Drewster, I have found that the silver ion cartridge helps the ozinator to do it's job, but if you feel it is not working for you, just don't replace it and see if you see any significant change
Post by: hymbaw on November 10, 2005, 03:40:52 pm
Am I over doing it?
Your impression is a correct one! Nature2 by itself is not enough. Ozone, by itself, is not enough. Combine the two and it's almost enough.
A little residual chlorine never hurt!
When you add di-chlor after each use you are indeed "shocking" the tub. Your weekly "shock" may not be needed but it sound like it's working for you. Try dropping the extra "shock" and see how it goes. If you have problems you can always add it back to your routine.
Good Luck
Post by: drewstar on November 10, 2005, 03:57:18 pm
Good Luck
Okay we are going to border on where I get outside my leauge. ...
A shock  breaks a certain level of chlorine in the tub. and oxidizes the contaminets that chlorine has killed and frees up the chlorine so it can continue to kill bacteria.
So,  if  I have enough free chlorine in my tub, I don't need to shock.
You can use a product thas has MPS to shock, or  I have also heard you can add a "super dose" of chlorine and achieve the same results. (Oxidation and freeing up of the chlorine).
What I don't get is, folks who are using no chlorine, Ion and ozone to kill bacteria,  since no chorine is being used, the shock is doing what? Burning up the contaminets that that ions and the 03 killed?
But not freeing up any chlorine, because they are not using any ?
Post by: svspa on November 10, 2005, 04:28:32 pm
Hymbaw, Drewstar,
One clarification, if you use dichlor as your sanitizer your weekly shock needs to be enough to oxidize the combined chlorines.
Taylor test kit recommends that is 10x the combined chlorine level in your tub. If your CC is 2ppm, then you need add enough dichlor to get your tub up to 20ppm.
Vermonter says a rule of thumb for that would be 3.5-7x your daily dose. Since each tub is different you need to experiment a little to find the dose needed for your normal use.
If your use changes you may have higher levels of combined chlorines and again need to adjust your shock accordingly.
You can tell if your shock is working if you can smell chlorine prior to shock and none after, you have successfully oxidized the combined chlorine.
Using dichlor on a daily basis in normal doses to keep a level of sanitizer will continue to build up the combined chlorines and increase chlorine smell/burning eyes until you successfully oxidize the combined chlorines with a dichlor or non-chlorine based shock dose.
Steve.
